| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Install |
| Date Logged & Current Version | Aug 2022 12.08.01.010 |
The fallowing appears when trying to install AutoPIPE
Failed to install Bentley Connection Client with error code 0x800705b4...
Why and how to avoid it?\
There could be any number of reasons why the installer could not run as intended (ex. Proxy Server settings, Virus protection, Permission, Company Policy, etc..). In this particular case a very specific error code was mentioned: 0x800705b4.
Search the internet for reasons and solutions to this error code.
In this case appears that 0x800705b4, is related to Windows Defender.
Suggest one of the following options before attempting to install AutoPIPE:
1. Contact company IT department and ask that they address any Windows Defender issues on your computer. Example, temporarily turn off Windows defender services while installing this application.
or
2. Download and install Connection Client on the computer before installing AutoPIPE.
After completing either step above, try again to install AutoPIPE on the computer.
Known errors that occur when installing
