Copy/protection device system does not support BS5950-2000(British/steel)design code.
I've upgraded to STAAD.Pro V8i Select series 5 (SS5) and while analyzing I get the message:
"Copy/protection device system does not support BS5950-2000(British/steel) design code. The design will not be performed." I have not seen this in the previous version of the program.
From  STAAD.Pro V8i Select series 5 (SS5) Build #20.07.10.41, the UK codes have been repackaged as below. Please contact your account manager to get this code pack included in your contract. If you need to use the code urgently, you may continue using the code in  SS4 version. Both SS4 and SS5 can be installed on the same workstation.
UK Super Code:-
Steel
Country
Code
Version
Comments
Europe
EN
1993-1-1
Including all implemented National Annexes
UK
BS 5400
UK
BS 5950
Part 1
UK
Part 5
Concrete
Country
Code
Version
Comments
Europe
EN
1992-1-1
UK
BS 8007
UK
BS 8110
Part 1
NOTE:
The same has happened to all European Design codes. EN 1993-1-1:2005 (with all National Annexes), EN 1992-1-1:1991 and design codes of Denmark, Finland, France, Germany, Netherlands, Norway, Russia, Spain and Sweden are all included in the ECC Super Codes license package in STAAD.Pro SELECTseries 5.
A more detailed explanation can be found in this Blog post:
Changes to Licensing in STAAD.Pro V8i SS5- Part 2, European Super Codes
