Cost codes configuration file
Cost code configuration example communities.bentley.com/.../274146
Cost code configuration template communities.bentley.com/.../274145
The cost codes breakdown structure needs to be defined in the Excel file.
Use the provided sample cost code configuration file as an example of how to define your own structure.
There are certain rules on how to set up the configuration file:
Once the cost codes configuration file is prepared successfully, upload it to the SYNCHRO CONTROL website -> Administration -> Cost Code Configuration. SYNCHRO Modeler automatically downloads the cost code configuration from SYNCHRO CONTROL for the selected project.
