| Version(s): | All | ||
| Area: | Postprocessing workflow | ||
| Subarea: | N/A | ||
What is the difference between the local and global deflection in the member query box?
Figures (1) and (2) show the local and global deflections of the beam #2 which is a part of the beam joining 2 columns:
Figure (1)
Figure (2)
Global deflection is the largest distance between (a) and (b) where:
(a) is the line joining the ends of the member in its un-deflected position (named as 'Original shape' in the figure (3));
(b) is the elastic curve of the member representing its deflected shape.
Local deflection is the largest distance between (c) and (d) where:
(c) is the line joining the ends of the member in its deflected position;
(d) is the elastic curve of the member representing its deflected shape.
Figure (3)
