| Version(s): | All | ||
| Area: | Postprocessing workflow | ||
| Subarea: | N/A | ||
If I have a moment vector along the local positive Z axis does it have a twisting action going to the right along the positive direction of the axis?
If a member is drawn with its longitudinal axis (local-X) from left to right, and the local Z axis coming out of the page towards you, a positive MZ would cause tension on the top fiber, and a negative MZ would cause tension on the bottom fiber.
