| Version(s): | All | ||
| Area: | Postprocessing workflow | ||
| Subarea: | N/A | ||
What is the purpose of the Beam - Graphs and how to use it?
This is another way to display the bending, shear and axial force diagrams on the screen.
In the post processing mode, select the Layout. Then select graphs under beam results.
The right side portion of the screen will display the Bending diagram (MZ), shear diagram (FY) and the axial force diagram (FX) with values. In the drawing area, if you select a member by clicking on it, MZ, FY and FX of
that member will be displayed on the right hand side. To display the diagrams of another member, select that member.
You can change the diagrams also in the graphs as per requirement. You need to right click on a graph and select Diagrams option.
It will now give to select different options. You can check any of them and the corresponding graph will be shown.
You can select any one of them or multiple as per your requirement. Clicking on the colors in that window, you may change them as per your need.
