| Version(s): | All | ||
| Area: | Postprocessing workflow | ||
| Subarea: | N/A | ||
How to know the version of the design code which is being used by STAAD.Pro during the analysis?
The design code version which is being used by STAAD.Pro during the design phase is written in the Output file
