| Version(s): | ALL |
| Area: | Heat Exchanger |
| Date Logged & Current Version | Apr 2024 44.00.01.014 |
How to add different gasket In gasketed Tubesheet connection In AES Heat Exchanger?
You can not use different gasket both side of Tubesheet if it has no extension.
Gasket can be different in case Tubesheet has separate bolt type extension.
Refer below steps to use separate bolt type extension,
Open the Tubesheet, go to the Geometry tab and select Extension Type as Yes, separate bolt.
