"Unable to set application resource” message
 Product(s):STAAD.Pro
 Version(s):N/A
 Environment: N/A
 Area: General
 Subarea:
 Original Author:Modestas Turulis, Bentley Technical Support Group
Error or Warning Message
Message "Unable to set application resource” is being reported while opening STAAD.Pro:
Explanation
Usually this message indicates that some settings in the registries are not correct and require some modifications.
How to Avoid
Option 1:
1) Log in as an Administrator.
2) Click on Windows Start button and then click on Run (on Windows XP) or click on Start button and go to the Search field (on Windows 7).
3) Type in "Regedit".
4) Click on "OK".
5) Go to HKEY_CLASSES_ROOT > StaadPro > 2007 > Language. (for STAAD.Pro SS6 folder 20.07.11 and for STAAD.Pro SS5 folder 20.07.10 instead of folder 2007).
6) Click on "Language" so that the key is highlighted in blue.
7) On the right window pane there should be a string value called "CurrentLanguage".
8) Is the data set to "USEnglish"? If not, double click on that string value to change the value data to "USEnglish". Please note that the value data is case sensitive.
Option 2:
If that string is missing, uninstall STAAD.Pro and then install it by running as administrator. Please note that even if you are logged in as administrator, the installer of STAAD.Pro still has to be run as administrator (right click on the installation file and select option 'Run As Administrator') on Windows 7/8 operating systems.
