| Version(s): | N/A | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Modestas Turulis, Bentley Technical Support Group | ||
Message "Catastrophic Failure” is being reported while opening STAAD.Pro:
This error usually is reported if the older version of ProjectWise is installed on the machine than ProjectWise V8i.
In order to avoid this error message, either ProjectWise should be removed from the machine or ProjectWise V8i or greater version should be installed on the machine were STAAD.Pro is running.
NOTE: this error message does not have any impact on the analysis or design results of STAAD.Pro.
