| Product(s): | STAAD Foundation Advanced | ||
| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | Postprocessing | ||
| Subarea: | N/A | ||
| Original Author: | Kris, Bentley Technical Support Group | ||
Question:
I am trying to see a graphical representation of the envelope of plate stresses and/or moments--how can this be done?
Answer:
Recently STAAD.pro was updated to include the option of viewing colored contour plots displaying plate results for an envelope of loads. Previously these plots could only be displayed on a load case by load case basis.
The following steps can be used to utilize this feature:
1. Run the analysis and go into Post Processing.
2. Under the Results ribbon, go to Layouts -> Plate Stress as shown below:
3. In the dialog box that appears, choose "Envelope" in the Load Case menu, select the desired stress type (say, MY (local)), and click Apply then OK:
4. The colored stress contour showing the stress envelope will appear on screen:
