| Version(s): | All | ||
| Area: | Concrete Design | ||
| Subarea: | American Concrete Design Codes | ||
If using an American code for code check, is there any parameter to define the material factor or is it already included?
The American codes do not have explicit material factors. Instead, they use "strength reduction factors". These strength reduction factors account for unavoidable variations in material strength, design equations, fabrication and erection. For example, in the American steel code LRFD 2001, these factors are : 0.90 for limit states involving yielding 0.75 for limit states involving rupture 0.85 for limit states involving compression buckling For the American concrete code ACI 318-02, some of the values used are Tension-controlled sections - 0.9 Compression controlled sections, members with spiral reinforcement - 0.7 Shear and Torsion - 0.75 Bearing on concrete - 0.65 etc. These are requirements placed by the code. So, we do not have parameters for altering these.
