| Version(s): | CONNECT Edition ( 21.00.00.57 and up ) | ||
| Environment: | ALL | ||
| Area: | Post Processing | ||
| Subarea: | |||
In older versions of STAAD.Pro (v8i), I was able to show the values of nodal displacements, moments, shears, support reactions etc. on the diagrams itself by going to Results > View Value. How can I do the same in the STAAD.Pro CONNECT Edition ?
After analyzing the model, go to the Postprocessing Mode.
Ensure that the relevant plot is turned on ( for example displaced shape OR bending moment OR shear force etc. )
Choose the Annotate option shown in the picture below
Click on the Annotate button within the dialog box to turn on the values
