| Environment: | ALL | ||
| Area: | STAAD.Pro Support Solutions | ||
| Subarea: | Physical Modeling workflow | ||
| Original Author: | Modestas Turulis, Bentley Technical Support Group | ||
Loading options to apply the nodal/member/surface load are not active in the Physical Modeler. Why?
This happens if there is no active Load Case or Load Group selected. Go to the Loading menu and select some Load Case or Load Group in the drop down list on the left hand side. Once the Load Case is selected all loading options for the nodes/members/surfaces should become active. This is required, because the program adds the loadings to the active load case or load group only.
