Use ADTT for γLL for legal loads
Setting the “γLL Strength I & II” = 0.000 provides Inventory and Operating γLL values = 1.75 (Inventory) and 1.35 (Operating) for all vehicles regardless of ADTT. It appears that LARS will only modify the γLL factors based on ADTT when the “Posting rating” is run.
When the Customization value – LRFR γLL for Strength I is non-zero, LARS Bridge will use the Customization value – LRFR γLL for Strength I legal loads. When the Customization value – LRFR γLL for Strength I is equal to zero, LARS Bridge will compute γLL for Strength I based on the ADTT input on the General Member Information dialog.
