LARS Bridge Result Comparison to MBE Examples
LARS Bridge has been run using MBE examples A1-A9 to compare results. Upcoming LARS version 6.00.01.01 was used in this comparison. The results are summarized below with any pertinent qualifications.
In general the comparisons are good. Variances occur due differences in:
Example A1 – Simple Span Composite Steel Stringer bridge
LRFD HL93 | |||||
Interior Girder | |||||
Limit state |
Design Load Rating | ||||
Inventory |
Operating | ||||
MBE |
LARS |
MBE |
LARS | ||
Strength I |
Flexure |
1.29 |
1.30 |
1.67 |
1.69 |
Shear |
2.44 |
3.16 |
3.16 | |
Strength II |
Flexure |
Shear |
Service II |
1.21 |
1.22 |
1.57 |
1.58 | |
Exterior Girder | |||||
Limit state |
Inventory |
Operating | ||||
MBE |
LARS |
MBE |
LARS | ||
Strength I |
Flexure |
1.40 |
1.37 |
1.81 |
1.77 |
Shear |
3.05 |
3.14 |
3.95 |
4.08 | |
Strength II |
Flexure |
Shear |
Service II |
1.48 |
1.38 |
1.92 |
1.8 | |
ASD HS20 | |||||
HS20 | |||||
Inventory |
Operating | |||
MBE |
LARS |
MBE |
LARS | ||
Flexure |
0.74 |
0.76 |
1.35 |
1.38 | |
LFD HS 20 | |||||
HS20 | |||||
Inventory |
Operating | |||
MBE |
LARS |
MBE |
LARS | ||
Flexure |
1.33 |
1.40 |
2.22 |
2.26 | |
Serviceability |
1.19 |
1.25 |
1.98 |
2.01 | |
Example A2 – Simple Span Reinforced Concrete T beam
LRFD HL 93 | |||||
Limit state |
Inventory |
Operating | ||||
MBE |
LARS |
MBE |
LARS | ||
Strength I |
Flexure |
0.59 |
0.59 |
0.76 |
0.77 |
Shear |
0.85 |
0.85 |
1.10 |
1.10 | |
ASD HS 20 | |||||
HS20 | |||||
Inventory |
Operating | |||
MBE |
LARS |
MBE |
LARS | ||
Flexure |
0.91 |
0.97 |
1.54 |
1.57 | |
LFD HS 20 | |||||
HS20 | |||||
Inventory |
Operating | |||
MBE |
LARS |
MBE |
LARS | ||
Flexure |
0.88 |
0.91 |
1.47 |
1.51 | |
Example A3 – Simple Span Prestressed Concrete I-Girder bridge
Limit state |
Inventory |
Operating | |||
MBE |
LARS |
MBE |
LARS | |
Strength I | ||||
Flexure (as midspan) |
1.48 |
1.47 |
1.92 |
1.91 |
Shear (at 64 in) |
1.96 |
1.12 |
Shear (at 20 ft) |
1.30 |
3.04 |
Service III | ||||
Flexure (at midspan) |
1.22 |
1.43 |
Note: Shear results between LARS and MBE cannot be compared as the MBE results used MCFT theory and LARS does not.
Example A4 – Simple Span Timber Stringer bridge
LRFD HL93 | |||||
Interior Stringer | |||||
LRFR Mode |
Inventory |
Operating | ||||
MBE |
LARS |
MBE |
LARS | ||
Strength I Limit State |
Flexure |
0.35 |
0.37 |
0.45 |
0.48 |
Shear |
1.07 |
1.08 |
1.39 |
1.39 | |
Example A5 – Four Span Continuous WPG bridge
LRFD HL93 | ||||
Limit state |
Inventory |
Operating | |||
MBE |
LARS |
MBE |
LARS | |
Strength I |
Flexure at 0.4L (+M) |
0.96 |
0.94 |
1.24 |
1.22 |
Flexure at 0.5L (+M) |
1.05 |
1.03 |
1.36 |
1.34 |
Flexure at pier 2 (-M) |
0.99 |
1.17 |
1.28 |
1.52 |
Shear at pier 1 |
1.75 |
1.8 |
2.27 |
2.34 |
Service II |
1 |
1.01 |
1.3 |
1.32 |
1.1 |
1.11 |
1.43 |
1.44 |
1.17 |
1.26 |
1.52 |
1.64 |
Example A6 – Single Span Through Pratt Truss bridge
MBE A6 | ||
Limit state |
Design Load Rating (HL-93) | |
Inventory | ||
MBE |
LARS | |
Strength I |
Top Chord TC4 |
1.97 |
2.04 |
Bottom Chord BC4 |
1.97 |
1.85 |
Diagonal D1 |
1.69 |
1.67 |
Vertical V1 |
2.4 |
2.27 |
Example A7 – Simple Span Reinforced Concrete Slab bridge
LRFD HL93 | |||||||
Limit state |
Design Load Rating | ||||||
Inventory |
Operating | ||||||
MBE |
LARS |
MBE |
LARS |
Strenghth I |
Flexure |
0.63 |
0.64 |
0.82 |
0.83 |
LFD HS-20 | |||||||
Interior Girder | |||||||
HS-20 |
Details | |||||
Inventory |
Operating |
MR |
MD |
MLL+I | |||
LARS |
LARS |
LARS |
LARS |
LARS | |||
Flexure |
0.17 |
0.29 |
52 |
12.4 |
95.7 | ||
Example A8 – Simple Span Two Girder Steel bridge
MBE A8 | ||||||
Floorbeam | ||||||
Limit state |
Inventory |
Operating | |||||
MBE |
LARS |
MBE |
LARS | |||
Strength I |
Flexure |
Max +M |
1.13 |
1.17 |
1.46 |
1.52 |
Max -M |
2.42 |
3.14 |
Shear |
1.6 |
1.43 |
2.07 |
1.85 | ||
Service II |
Flexure Max +M (Governs) |
1.06 |
1.27 |
1.38 |
1.64 | |
Girder | ||||||
Limit state |
Inventory |
Operating | |||||
MBE |
LARS |
MBE |
LARS | |||
Strength I |
Flexure |
1.11 |
1.27 |
1.44 |
1.64 | |
Shear |
1.89 |
1.64 |
2.45 |
2.12 | ||
Example A9 – Simple Span Prestressed Concrete Adjacent Box Beam bridge
MBE A9 | |||||
Limit state |
Inventory |
Operating | ||||
MBE |
LARS |
MBE |
LARS | ||
Strength I |
Flexure |
1.25 |
1.28 |
1.61 |
1.65 |
Service III |
1.35 |
1.22 |
