LARS: Default floorbeam spacing
To compute the the liveload reaction to a floorbeam, the floorbeam spacing must be input into LARS. If the floor beam spacing is not input, a default spacing value of 1.0 ft is used to prevent a divide by 0 and subsequent program crash.
