| Version(s): | V8i (20.07.09.XX) and later | ||
| Area: | STAAD.Pro Download/Installation/Security/Performance | ||
| Subarea: | Installation | ||
| Original Author: | Payel Sasmal, Bentley Technical Support Group | ||
How do I download/install SectionWizard? I do not see it in the Software Fulfillment center.
There is no separate installation for SectionWizard. It is installed along with STAAD.Pro. No license configuration is needed to run this module.
Please make sure that SectionWizard is launched from the STAAD.Pro menu as illustrated here. This is a free module provided for STAAD.Pro users.
If you are using STAAD.Pro CONNECT Edition, you will find this in Analytical Modelling section.
