I do not see the AISC 360-16 code listed in the list of design codes in the STAAD.Pro Connect Editio
Product(s):STAAD.Pro
Version(s):21.00.01.12 upwards ( Connect Edition )
Environment: ALL
Area: STAAD.Pro Download/Installation/Security/Performance
Subarea:  Performance
Original Author:Sye Chakraborty, Bentley Technical Support Group
The STAAD.Pro Connect Edition Update 1 is supposed to have the AISC 360-16 code. However when I go to the Design page, I do not see the code in the list of available codes? Can you please tell me why ?
Possibly the program is still using the application INI from a previous version of STAAD.Pro Connect Edition.
Please follow the steps below to fix the issue
  1. Exit all running sessions of STAAD.Pro application.
  2. Delete the folder C:\Users\<User.Name>\AppData\Local\Bentley\Engineering\STAAD.Pro CONNECT Edition\Default. Note that <User.Name> is to be replaced by actual user profile name.
  3. Restart STAAD.Pro application.
This time (and going forward), you should see AISC 360-16 code listed.
