| Product(s): | STAAD.Pro, STAAD Foundation Advanced | ||
| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | STAAD.Pro Download/Installation/Security/Performance | ||
| Subarea: | Performance | ||
The ribbon menu and the icons look bigger than usual and I am not able to see the full content of the dialog boxes. Can you please suggest what could be the reason ?
From the Windows Start Button, access Settings and follow the steps below
If the setting is already at recommended and you are still having the issue, try using the next lower percentage
