| Product(s): | STAAD.pro | ||
| Version(s): | All | ||
| Area: | STAAD.Pro Download/Installation/Security/Performance | ||
The STAAD display is larger than my visible screen size, so I cannot see the "close" or "OK" buttons typically located at the bottom of the screen.
I do not see the STAAD Foundation Advanced button too.
The most likely cause of this problem is the screen resolution setting on your machine. It should be as high as possible, however we at least recommend using 1280X1024.
There have been few cases, where the maximum resolution available in a laptop/tablet is 1024 X 768; in that case, change the text size to small in Control Panel\Appearance and Personalization\Display setting as shown here.
You may need to change the default text size too.
