| Version(s): | STAAD.Pro CE | ||
| Environment: | ALL | ||
| Area: | STAAD.Pro Download/Installation/Security/Performance | ||
| Subarea: | Performance | ||
When I launch the STAAD.Pro Connect Edition, I get the following error message
OR
What should I do to rectify this issue ?
Here are a list of Options for you to try out
Option 1
You are getting the message most likely because the Bentley Property Catalog Service is stopped in your machine. You will need to start this service.
Next time when you start the software, the error message should not appear.
Option 2
If the option 1 does not resolve the issue, please try running STAAD.Pro CE as an administrator. To do that simply right click on the shortcut for STAAD.Pro CE and choose Run as Administrator.
Option 3
If neither options 1 and 2 work for you, please follow the steps below
