Beam Design Validation (Intermediate Frame) - flexural and shear
Beam_Intermediate_Design calculation from RCDC
Beam Design Validation (Special Frame) - flexural and shear
Beam_Special_Design calculation from RCDC
Beam Sway Shear Validation (Special Frame)
Beam_ACI_318M_2014_Sway Shear calculation
Beam Crack width check
Beam Coupling design Validation
Beam_ACI 318M-2014_Coupling_R0
Column Flexural design (Braced frame) Validation
Column_ACI_318M-2014_Column Flexural Design_Braced
Column Flexural design (Un-Braced frame) Validation
Column_ACI_318M-2014_Column Flexural Design_UnBraced
Column Validation (Intermediate Frame)
Column_Intermediate_Design calculation_Validation sheet
ACI 318M-2014 (Metric) Column Shear Design and Ductile links design - Special Frame
Column_ACI_318M-2014_Column_Special_Shear Design
ACI 318M-2014 (Metric) Column Shear Design and links design - Non Ductile
Column_ACI_318M-2014_Column_Regular_Shear Design_R0
Column_Effective Length Factor calculation
Column_ACI_318M-2014_Effective Length factor_Validation sheet
Joint Check for column and beam - Ductile design for Special frame
Column Beam Joint Check Validation Document_ACI 318M 2014
Slab Design (Direct Design Method)
Slab_ACI_two way_Validation Sheet
1 Pile Pilecap design
Pilecap_ACI_Pilecap_1pile_Validation sheet#
2 Piles Pilecap Design
Pilecap_ACI_Pilecap_2piles_Validation sheet
3 Piles Pilecap design
Pilecap_ACI_Pilecap_3piles_Validation sheet
4 Piles Pilecap Design
Pilecap_ACI_Pilecap_4piles_Validation sheet
5 Piles Pilecap Design
Pilecap_ACI_Pilecap_5piles_Validation sheet
6 Piles Pilecap Design
Pilecap_ACI_Pilecap_6piles_Validation sheet
