American Concrete design code ACI 318-2019 (FPS Unit)
Following are the Validation sheets for various elements available in RCDC as per ACI 318-2019 design code.
Beam design for Flexural, Shear and torsion_Special frame
B1_Design Calculation Report_RCDC Output
Beam Sway shear calculation- Special frame
Beam - Crack-width check
Beam_ACI_318_2019_Beam CrackWidth
Beam-Coupling Beam Validation
B2_Beam Design calculation report
Coupling beam-testing-model-2
Column Flexural Design-Non Sway (Braced) Frame
C1_slender column flexural design
Column Flexural Design-Sway (Un-Braced) Frame
ACI_318-2019_Column Flexural Design_UnBraced_R0
Column Effective length factor calculation
Column_ACIE 2019 code_Effective Length factor_Validation sheet
