| Version(s): | 10.04.00.46 | ||
| Area: | CONNECT Integration | ||
| Subarea: | CONNECT Advisor |
Note: This article was created thanks to Jan Slegr
1. Go to directory, example C:\Users\{Windows UserID}\AppData\Local\Bentley\Logs\
2. Look for SmartAdvisorLog.exe.log
3. Send the logs to Technical Support
or
4. otherwise you can open the logs with notepad and go to Edit\Find and type: Error
3. Press the find next button
The first message we get is:
An exception occurred while trying to Error in PWCS service Get Response.
Exception Message: System.Net.WebException:
The remote server returned an error: (404) Not Found” and Logging PWCS API response is null.
Note: This changes should be done by your IT Department.
1. Go to Control Panel
2. In Programs and Features group, find “Turn Windows features on or off” on the left side of the window
3. Go to .NET Framework 4.6 Advanced Services > WCF Services
4. Switch on "HTTP activation"
Forum Thread in relation to CONNECT Advisor
| Original Author: | Maria Munoz |
