American Concrete design code ACI 318-2014 (English Unit)
ACI English Unit_Beam Crack width Validation Sheet
ACI_English_Beam Crack-width
ACI 318-2014 (English) - Beam Sway Shear calculation
ACI 318-2014_Beam Sway shear Validation sheets
Beam Coupling design Validation
ACI 318-2014 Beam Coupling Design
ACI 318-2014 (English) Column Flexural Design - Braced - Non Ductile
ACI_318-2014_Column Flexural Design Braced (Non Ductile)
ACI 318-2014 (English) Column Shear Design and links design - Non Ductile
Column_ACI_318-2014_Column_Non ductile_Shear Design
ACI 318-2014 (English) Column Shear Design and links design - Intermediate frame
Column_ACI_318-2014_Column_Intermediate_Shear Design
ACI 318-2014 (English) Column Shear Design and Ductile links design - Special Frame
ACI_318-2014_Column_Special_Shear Design
ACI 318-2014 Column Effective length factor calculation
Column_ACIE 2014 code_Effective Length factor_Validation sheet
