| Version(s): | 08.01.02.15 | ||
| Area: | Text | ||
| Subarea: | General | ||
Unable to extrude text with Feature Modeling tools.
Resource fonts generally have geometry problems. The MicroStation 3D extrude tool will work on any geometry. The feature modeling tool requires proper shapes. Therefore, use True Type fonts. Arial looks the same as the Block Outlined text, which is generally used to extrude.
