| Version: | All Versions | ||
| Area: | Installation | ||
| Subarea: | General |
A return happens after a few words - After placing a few words an automatic return happens, why?
This can happen when the Line Length set too low. It might be needed to set it higher or to the default which is 250. It is possible to do so by editing the Line Length setting in the Text toolbox or using the key-in ll=
How to increase the allowable line length of text in Word Processor
The Text Editor Ruler is short
