| Version(s): | N\A | ||
| Area: | Text | ||
| Subarea: | Fields | ||
| Original Author: | Marta Babiakova, Bentley Technical Support Group | ||
How to automatically update text fields when opening a file.
If a file contains text fields (File properties, File size, File name for example) and you want to update these fields automatically when the file is opened, set the configuration variable MS_AUTO_UPDATE_FIELDS to ALWAYS.
The Key-in field update all will also accomplish this.
