| Version(s): | 08.05.00.64 | ||
| Area: | Text | ||
| Subarea: | Fonts | ||
Can not see SHX font types in Font dialog in MicroStation v8.
When opening a DWG in Microstation, the fonts don't show up.
To resolve AutoCAD font files.
1. Obtain the .shx file(s)
2. Go to Workspace > Configuration > scroll to MS_DWGFONTPATH.
3. Set this variable to the folder containing the AutoCAD (.shx) font(s)
Note: If AutoCAD is installed before MicroStation is installed, MicroStation will automatically find the location of AutoCAD's font folder.
