| Version(s): | 08.05.02.35 | ||
| Area: | Text | ||
| Subarea: | Word Processor | ||
Change text placed with the Word Wrap method to text placed with By Origin.
Product: MicroStation 2004 Edition
Version: 08.05.02.35
1. Select the Edit Text and select the text you want to edit.
2. With the Text Editor - Word Processor open from Step 1, select the Place Text tool.
3. In the Place Text tool settings window, make sure the Method is set to By Origin and place the new text. It should adhere to your Line Length setting.
4. Delete the old text and move the new text accordingly.
