| Version(s): | 08.05.02.35 | ||
| Area: | Text | ||
| Subarea: | Fonts | ||
ERROR: Character 201 does not have a Level=63 shape.
When installing the working.cel using the font installer an information box pops up and says "Character '201' does not have level=63 shape" what does this mean?
This means that there should be a shape on level 63 and this shape does not exist. You will need to modify the character and place a shape around it on level called "level 63".
