| Version(s): | 08.05.02.35 | ||
| Area: | Text | ||
| Subarea: | Fonts | ||
FT= keyin command.--When trying to specify the Arial true type font with the FT=<font name> keyin command it is pulling the Arial font from the resource file rather then reading the actual true type font.
The FT= keyin command is a legacy keyin. It will pull the arial font from the Microstation resource file.
