| Version(s): | All | ||
| Area: | Analysis Solutions | ||
| Subarea: | Dynamic Analysis | ||
| Original Author: | Sanjib Das & Rajat Chakroborty | ||
CALCULATING MODES AND FREQUENCIES
In STAAD, there are 2 methods for obtaining the frequencies of a structure.
• The Rayleigh method using the CALCULATE RAYLEIGH FREQUENCY command
• The elaborate method which involves extracting eigenvalues from a matrix based on the structure stiffness and lumped masses in the model.
The Rayleigh Method
The Rayleigh method in STAAD is a one-iteration approximate method from which a single frequency is obtained. It uses the displaced shape of the model to obtain the frequency. Needless to say, it is extremely important that the displaced shape that the calculation is based on, resemble one of the vibration modes. If one is interested in the fundamental mode, the loading on the model should cause it to displace in a manner which resembles the fundamental mode. For example, the fundamental mode of vibration of a tall building would be a cantilever style mode, where the building sways from side to side with the base remaining stationary. The type of loading which creates a displaced shape which resembles this mode is a lateral force such as a wind force. Hence, if one were to use the Rayleigh method, the loads which should be applied are lateral loads, not vertical loads.
To obtain the natural frequency using the RAYLEIGH METHOD, you have to specify the command CALCULATE RAYLEIGH FREQUENCY in the load case in which the load data which produce a mode-shape type deflected shape are specified.
Eigenvalue extraction method
This method is based on extracting eigen values and eigenvectors using the stiffness and mass matrices of the structure. If the stiffness and mass data are specified correctly, this is a far more reliable method than the Rayleigh method. In modal analysis we solve:
For the Eigen solution method, the user is required to specify all the masses in the model along with the directions they are capable of vibrating in. If this data is correctly provided, the program extracts as many modes as the user requests (default value is 6) in ascending order of strain energy. The mode shapes can be viewed graphically to verify that they make sense.
To use the Eigen value method, specify the command MODAL CALCULATION REQUESTED in the load case in which the load data for the mass matrix are specified. For an example which illustrates this method, please refer to Example 28 within Application Examples.
Also, the Rayleigh cases should not have the MODAL CALC or dynamics in the same case. Remember to leave these Rayleigh cases and the MODAL CALC REQUESTED load cases out of the Load List for design.
