| Version(s): | N\A | ||
| Area: | Text | ||
| Subarea: | Text Styles | ||
| Original Author: | Ignacio Balestra, Bentley Technical Support Group | ||
How to change the distance of Superscript.
To create a superscript that has a different distance than standard, do the following:
(1) Create 2 styles, one for the normal text, and the other for the superscript.
(2) When you place text, turn the Apply Change to All Text setting off.
(3) To change the distance of the superscript, in relation to the normal text, you need to change Line Offset.
