| Version(s): | V8 | ||
| Area: | Dimensions | ||
| Subarea: | Notes | ||
Can the leader line that has been created by using the tool "Place Note" be placed at different lengths?
Set Location to 'manual' and set Orientation to 'in-line'. Define Start point in the View, and Reset to complete when the desired length has been reached
communities.bentley.com/.../how-to-control-the-text-settings-of-a-note
