| Version(s): | 08.05.01.25 | ||
| Area: | Text | ||
| Subarea: | N\A | ||
How to place text with an outline and a fill.
While working in MicroStation J the raster can be clipped although there is a 101 vertice limit. If the text is under the ariel photo then the update sequence option can be used. In Microstation V8 there is a new text background feature which is like having a filled shape with an outline with the text on top.
