| Version(s): | All | ||
| Area: | Analysis Solutions | ||
| Subarea: | Instability And Zero Stiffness | ||
I tried to model a concrete foundation using solid elements, basically following the approach described in example 24 of the examples manual. However, I got this warning stating "more than 12 DOF with zero stiffness". Can anyone please advise me what are the technical reasons for this and how I can possibly handle this warning?
A solid element by its basic nature does not have rotational degrees of freedom at its nodes. So, at all points on the structure where the only entities connected are solid elements, there is no rotational stiffness.
For an explanation on the reasons behind zero stiffness messages click here
If you are using STAAD.Pro 2003 Build 1003.US or later, and the only entities in your structure are solids (no plates or beams), the program automatically applies restraints along those rotational degrees of freedom and the messages will hence not appear. However, if beams or plates are present in the structure in addition to solids, those messages will be present.
If you do not encounter instability warning messages in your output, and the applied loads are in equilibrium with support reactions, you may consider the zero stiffness warning messages harmless, and ignore them.
