| Version(s): | N\A | ||
| Area: | Dimensions | ||
| Subarea: | Notes | ||
| Original Author: | Lynn Winkler, Bentley Technical Support Group | ||
In-line leader in a Place Note disappears when dwg file is saved.
Use Change Dimension tool to reset to active Dimension Style and in-line leader returns. But save the dwg file and the in-line leader disappears again.
This is an AutoCAD limitation. If the angle between the leader and in-line leader is less than 15 degrees, AutoCAD will eliminate the in-line leader.
Solution is to move the Text portion of the Place Note so that the angle between the leader and in-line leader is greater than
15 degrees.
