| Version(s): | All | ||
| Area: | Analysis Solutions | ||
| Subarea: | Instability And Zero Stiffness | ||
When we generate the spring supports for a raft foundation using the command "list-of-joints Elastic mat Dir YONLY SUB 10000" we get instability warnings in FX, FZ and MY directions at certain joints. Why?
The Elastic Mat instability messages have to do with the Y option versus the YONLY option. The Y option automatically fixes the FX and FZ directions at all mat joints whereas the YONLY option does not. Without any support in the FX and FZ directions, your structure is unstable in these directions and MY as well. You could switch to the Y option or perhaps fix FX, FZ and MY at one joint near the center. Since STAAD automatically applies very small springs at one joint to stabilize an unstable structure, you could ignore the messages if there are no FX, FZ, or MY loadings and if the displacements are small in those directions.
