| Version(s): | 08.09.04.51 | ||
| Area: | Text | ||
| Subarea: | Fields | ||
| Original Author: | Elisa Pry, Bentley Technical Support Group | ||
Where can I find information on inserting fields in text?
Product: MicroStation V8 XM Edition
Version: 08.09.04.51
Help > Contents > Composing Drawings > Annotations > Placing Text > Fields
A detailed description can also be found here:
http://communities.bentley.com/products/microstation/w/microstation__wiki/14561.add-enter-data-fields-to-existing-text
