| Version(s): | 08.11.07.443 | ||
| Area: | Text | ||
| Subarea: | Fonts | ||
| Original Author: | Henricus Ligtvoet, Bentley Technical Support Group | ||
Justification and origin of text placed in MicroStation 2004 Edition is different in MicroStation V8i.
Product: MicroStation V8i
Version: 08.11.07.443
(1) Make sure the engineering.rsc font file is in a path specified by MS_FONTPATH.
(2) Check the MstnFontConfig.xml to permit this font to be used.
(3) Delete the contents of the folder GeneratedTTFonts in the MicoStation temp folder (default: MS_TMP).
(4) Restart MicroStation V8i.
