| | Product: | MicroStation | |
| | Version: | 08.11.09.459 | |
| | Environment: | N\A | |
| | Area: | Text | |
| | Subarea: | Fonts | |
Problem Description
I want to assign different fonts to the several tags of a placed tag set but when I try to change the font of one member all tags will get this font.
Steps to Resolve
- Place a fence around the tags and execute the Key-In "fence freeze". This will turn the tags to normal text.
- Change each text (tag) to the desired font.
- Place a fence around the text (tags) and execute the Key-In "fence thaw". This will turn the texts to tags again.
See also
Other language sources
| | Original Author: | Sven Ziegelski | |
