| Version: | 08.05.02.70 | ||
| Area: | Text | ||
| Subarea: | General |
There is no key-in for PLACE TEXT ORIGIN or PLACE DIALOGTEXT ORIGIN. The key-in PLACE TEXT | DIALOGTEXT defaults to the last method used for placing text.
Use string of DMSG key-ins to place text by origin:
PLACE DIALOGTEXT ICON = activate the Place Text tool
DMSG FOCUSDIALOG TOOLSET = give focus to the Tool Settings dialog box
DMSG FOCUSITEM 0 = give focus to the first item in this dialog box
DMSG ACTION OKAY = open this item
DMSG CURSOR LINEBEGIN = go to the first item in the drop down list
DMSG ACTION OKAY = accept the selection in the drop down list
Solution is valid for MicroStation XM Edition, MicroStation 2004 Edition, and MicroStation V8i.
