| Version(s): | 08.05.01.25 | ||
| Area: | Dimensions | ||
| Subarea: | General | ||
Place note with underline text in MicroStation 08.05.01.25.
When placing a note, the text is not underlined like it was in Previous MicroStation J version.
User will need to set the in-line leader option and also set the underline option for the left and right of the leader.
