| | Applies To | | |
| | Product(s): | MicroStation | |
| | Version(s): | 08.11.09.459 | |
| | Environment: | N/A | |
| | Area: | Text | |
| | Subarea: | Fonts | |
| | Original Author: | Conor King, Bentley Technical Support Group | |
Problem Description
When browsing to load an RSC font file into Font Utilites, the file does not load, Font Utilities remains blank
Steps to Resolve
The RSC file could be set to Read-only. To change this:
- Using Windows Explorer, browse to the location of the RSC font file
- Right click on the file and select Properties
- In the General tab of Properties dialog uncheck the Read-only Attribute
- Click OK to close Properties dialog
- Try loading the RSC font file into the Font Utilites again - file should load and fonts are now listed
Font Utilities
