| Version(s): | 08.05.02.35 | ||
| Area: | Text | ||
| Subarea: | Match / Change Attributes | ||
Setting intercharacter spacing with change text attributes tool.
When trying to change text attributes using the change text attributes tool. When setting the intercharacter spacing to 0 text is going on top of itself.
Workspace > Preference > Fixed with character spacing is toggled on. Suggested that this be turned off.
