Error "LoadLibrary failed with error 126: The specified module could not be found" while clicking on
 Product(s):STAAD.Pro
 Version(s):20.07.10.66
 Environment: N\A
 Area: Analysis Solutions
 Subarea: Miscellaneous Analysis Solutions
 Original Author:Modestas Turulis, Bentley Technical Support Group
Error "LoadLibrary failed with error 126: The specified module could not be found" occurs while clicking on 3D Rendered View icon in STAAD.Pro or while going to Beam -> Stresses tab in the Postprocessing mode.
How to avoid this message?
a. Click on Start, click All programs, click Accessories, right click on Command prompt and select Run as administrator.
b. Type in the following commands and hit enter after each command
      Cd /d C:\Windows\System32
      Copy atioglxx.dll .dll
c. Exit the command prompt and check for the issue.
