| Version(s): | 08.05.00.64 | ||
| Area: | Text | ||
| Subarea: | General | ||
When the Text Editor style is set toDialog Box, how to get the keyboard commands to accept the Apply, Reset or Spelling buttons to activate?
After the text is completed, press the Tab button to move the focus to the Apply button. Pressing the space bar will accept the Apply button. Pressing Tab will cycle through. The other alternative is to use the Alt+A, Alt+R or Alt+S combinations for the Apply, Reset or Spelling, respectively.
