| Version(s): | 07.00.01.11 | ||
| Area: | Text | ||
| Subarea: | General | ||
Text node Justification in MicroStation J.
Text nodes that report a justification of LC displays on the right side of the text element.
Will need to use the edit text tool and replace the text. This will need correct the text node number.
